查看: 1132|回复: 12
[已解答] blinker做的卧室灯开关发现一个问题
发表于 2020-5-29 11:39 | 显示全部楼层 |阅读模式
做了一个卧室灯开关并安装到墙壁86盒中,实现了小爱同学,墙壁开关点动控制开关灯.看起来一切正常.但是有时半夜没有操作灯自动亮了,可能是某些信息号干扰,但不知如何解决?
接线图如下
程序如下
[mw_shl_code=arduino,true]#define BLINKER_WIFI
#define BLINKER_MIOT_LIGHT
#define BLINKER_PRINT Serial
#include <ESP8266WiFi.h>
WiFiServer server(80);
char auth[] = "123";
char ssid[] = "123";
char pswd[] = "123";
int GPIO = 0;
//实体按钮开关
int switch_button = 2;
int temp = 0;
BlinkerButton ButtonOn("btn-on");
BlinkerButton ButtonOff("btn-off");
BlinkerButton ButtonState("btn-state");
void button_on_callback(const String & state) {
  digitalWrite(GPIO, HIGH);
  ButtonState.print("on");
  ButtonState.color("#00BB00");
  ButtonState.text("灯亮了");
  Blinker.vibrate();
void button_off_callback(const String & state) {
  digitalWrite(GPIO, LOW);
  ButtonState.print("off");
  ButtonState.color("#FF0000");
  ButtonState.text("灯关了");
  Blinker.vibrate();
    BlinkerMIOT.powerState("on");
    BlinkerMIOT.print();
void heartbeat()
  BLINKER_LOG("状态同步!");
  if (digitalRead(GPIO) == LOW)
  BLINKER_DEBUG.stream(Serial);
  pinMode(GPIO, OUTPUT);
  pinMode(switch_button, INPUT);
  ButtonOn.attach(button_on_callback);
  ButtonOff.attach(button_off_callback);
  server.begin();
  Serial.println(F("Server started"));
  temp = digitalRead(switch_button);
  if (temp == LOW) {
    digitalWrite(GPIO, !digitalRead(GPIO));
    pinMode(switch_button, INPUT_PULLUP);
    delay(300);
  WiFiClient client = server.available();
  if (!client) {
    return;
  String req = client.readStringUntil('\r');
  Serial.println(req);
  client.flush();
  int val;
  if (req.indexOf("/gpio/on") != -1)
  else if (req.indexOf("/gpio/off") != -1)
  else {
    Serial.println("invalid request");
    client.print("HTTP/1.1 404\r\n");
    client.stop();
    return;
  client.flush();
  // Prepare the response
  String s = "HTTP/1.1 200 OK\r\nContent-Type: text/html\r\n\r\n<!DOCTYPE HTML>\r\n<html>\r\nWelcome to 666! ";
  s += "</html>\n";
  client.print(s);
  delay(1);
  Serial.println("Client disonnected");
    发表于 2020-5-29 12:08 | 显示全部楼层
    估计是设备重启了,具体只有看设备调试信息。
     楼主| 发表于 2020-5-29 14:54 | 显示全部楼层
    重启默认是关闭状态,灯也应该不亮才对啊,现在是自动触发了
    1.控制程序都是你自己写的,服务器不会发送控制信息。 2.重启时或程序出错,需要自己判断了 3.看调试信息  详情 回复 发表于 2020-5-29 16:24
    发表于 2020-5-29 16:24 | 显示全部楼层
    2.重启时或程序出错,需要自己判断了
    3.看调试信息
    发表于 2020-6-1 00:52 | 显示全部楼层
    如果排除程序问,用的是图片所示的AC-DC没有隔离电源。个人觉得应当是电源问题,遇到电涌导致三极管打开。换个隔离DC电源或纯充电宝供电试试看吧。
    2020-7-3 09:39
  • 签到天数: 465 天
    发表于 2020-6-1 22:25 | 显示全部楼层
    暗盒开关线很容易受电源线干扰,
    GPIO  接一个10K下拉电阻。
    2020-7-2 21:23
  • 签到天数: 260 天
    发表于 2020-6-1 22:57 | 显示全部楼层
    设计时要考虑手动关闭的,再考虑远程自动关闭,否则就会非常尴尬。
    发表于 2020-6-11 22:25 | 显示全部楼层
    楼主你那个点动开关不是执行复位的么 怎么控制开关灯啊
    2020-6-15 21:13
    发表于 2020-6-16 09:26 | 显示全部楼层
    楼主,用了您的代码,为什么连小爱都控制不了
     楼主| 发表于 2020-6-17 15:18 | 显示全部楼层
    目前已经正常
    求助,用l298n模块控制电
    绑定github账号,免费增加设备额度
    绑定github账号,免费增加
