查看: 1697|回复: 1
M5StickC典型应用示例
发表于 2020-6-2 15:33 | 显示全部楼层 |阅读模式
1.WiFiClient设置RTC时间
[mw_shl_code=arduino,true]#include <M5StickC.h>
#include <WiFi.h>
#include <WiFiClient.h>
#include <WiFiAP.h>
#include "time.h"
const char *ssid = "RTC";
const char *password = "";
WiFiServer server(80);
RTC_TimeTypeDef RTC_TimeStruct;
RTC_DateTypeDef RTC_DateStruct;
int lastDrawTime = 0;
  M5.begin();
  M5.Lcd.setRotation(3);
  M5.Lcd.fillScreen(BLACK);
  M5.Lcd.setTextSize(1);
  M5.Lcd.setCursor(40, 0, 2);
  M5.Lcd.println("RTC AP TEST");
  Serial.println("Configuring access point...");
  WiFi.softAP(ssid, password);
  IPAddress myIP = WiFi.softAPIP();
  Serial.print("AP IP address: ");
  Serial.println(myIP);
  server.begin();
  M5.Lcd.print("AP : " );
  M5.Lcd.println(ssid);
  M5.Lcd.print("IP : " );
  M5.Lcd.println(myIP);
  WiFiClient client = server.available();
  if (client) {
    Serial.println("New Client.");
    String currentLine = "";
    while (client.connected()) {
      if (client.available()) {
        char c = client.read();
        Serial.write(c);
        if (c == '\n') {
          if (currentLine.length() == 0) {
            client.println("HTTP/1.1 200 OK");
            client.println("Content-type:text/html; charset=utf-8;");
            client.println();
            client.println("<!DOCTYPE HTML>");
            client.println("<html>");
            client.println("<head>");
            client.println("<meta name=\"viewport\" content=\"width=device-width,initial-scale=1\" />");
            client.println("<script>");
            client.println("function clickBtn(){");
            client.println("  var jikan= new Date();");
            client.println("  document.time.year.value = jikan.getFullYear();");
            client.println("  document.time.mon.value  = jikan.getMonth()+1;");
            client.println("  document.time.day.value  = jikan.getDate();");
            client.println("  document.time.week.value  = jikan.getDay();");
            client.println("  document.time.hour.value = jikan.getHours();");
            client.println("  document.time.min.value  = jikan.getMinutes();");
            client.println("  document.time.sec.value  = jikan.getSeconds();");
            client.println("}");
            client.println("</script>");
            client.println("</head>");
            client.println("<body>");
            client.println("<form method=\"get\" name=\"time\">");
            client.println("<table>");
            client.println("<tr><th>year</th><td><input type=\"text\" name=\"year\" value=\"1900\" />1990-2099</td></tr>");
            client.println("<tr><th>mon</th><td><input type=\"text\" name=\"mon\" value=\"1\" />1-12</td></tr>");
            client.println("<tr><th>day</th><td><input type=\"text\" name=\"day\" value=\"1\" />1-31</td></tr>");
            client.println("<tr><th>week</th><td><input type=\"text\" name=\"week\" value=\"0\" />0-6</td></tr>");
            client.println("<tr><th>hour</th><td><input type=\"text\" name=\"hour\" value=\"0\" />0-23</td></tr>");
            client.println("<tr><th>min</th><td><input type=\"text\" name=\"min\" value=\"0\" />0-59</td></tr>");
            client.println("<tr><th>sec</th><td><input type=\"text\" name=\"sec\" value=\"0\" />0-59</td></tr>");
            client.println("<tr><th></th><td><input type=\"button\" value=\"设置浏览器时间\" onclick=\"clickBtn()\" /></td></tr>");
            client.println("<tr><th></th><td><input type=\"submit\" value=\"更新\" /></td></tr>");
            client.println("</table>");
            client.println("</form>");
            client.println("</body>");
            client.println("</html>");
            Serial.println("html Rendering");
          } else if (currentLine.indexOf("GET /?") == 0) {
            int pos1 = 0;
            int pos2 = 0;
            int val = 0;
            // Set RTC time
            RTC_TimeTypeDef TimeStruct;
            RTC_DateTypeDef DateStruct;
            // year
            pos1 = currentLine.indexOf('year=', pos2);
            pos2 = currentLine.indexOf('&', pos1);
            val = currentLine.substring(pos1 + 1, pos2).toInt();
            DateStruct.Year = val;
            pos1 = currentLine.indexOf('mon=', pos2);
            DateStruct.Month = val;
            pos1 = currentLine.indexOf('day=', pos2);
            DateStruct.Date = val;
            pos1 = currentLine.indexOf('week=', pos2);
            DateStruct.WeekDay = val;
            pos1 = currentLine.indexOf('hour=', pos2);
            TimeStruct.Hours = val;
            pos1 = currentLine.indexOf('min=', pos2);
            TimeStruct.Minutes = val;
            pos1 = currentLine.indexOf('sec=', pos2);
            pos2 = currentLine.indexOf(' ', pos1);
            TimeStruct.Seconds = val;
            M5.Rtc.SetTime(&TimeStruct);
            M5.Rtc.SetData(&DateStruct);
            client.println();
            client.println("更新<br />");
            client.println("[<a href=\"/\">返回</a>]<br />");
            Serial.println("RTC Update");
          } else {
            currentLine = "";
        } else if (c != '\r') {
          currentLine += c;
    client.stop();
    Serial.println("Client Disconnected.");
  if( lastDrawTime + 500 < millis() ){
    static const char *wd[7] = {"Sun", "Mon", "Tue", "Wed", "Thr", "Fri", "Sat"};
    M5.Rtc.GetTime(&RTC_TimeStruct);
    M5.Rtc.GetData(&RTC_DateStruct);
    M5.Lcd.setCursor(0, 16 * 2);
    M5.Lcd.printf("Data: %04d-%02d-%02d(%s)\n", RTC_DateStruct.Year, RTC_DateStruct.Month, RTC_DateStruct.Date, wd[RTC_DateStruct.WeekDay]);
    M5.Lcd.printf("Time: %02d : %02d : %02d\n", RTC_TimeStruct.Hours, RTC_TimeStruct.Minutes, RTC_TimeStruct.Seconds);
    lastDrawTime = millis();
2.电源联动自动关机
// 最后确认电压的时间
int lastVinTime = 0;
// 关闭AXP的电源
void axp_halt(){
    Wire1.beginTransmission(0x34);
    Wire1.write(0x32);
    Wire1.endTransmission();
    Wire1.requestFrom(0x34, 1);
    uint8_t buf = Wire1.read();
    Wire1.write(0x32);
    Wire1.write(buf | 0x80); // halt bit
  M5.begin();
  M5.Lcd.fillScreen(WHITE);
  if( (M5.Axp.GetVinData()*1.7) < 3.0 ){
    if( lastVinTime + 5000 < millis() ){
      // 3.0V以下5秒以上关闭电源
      axp_halt();
  } else {
    // 最终电压确认时间更新
    lastVinTime = millis();
3.PPT蓝牙遥控器
#include <BleKeyboard.h>
BleKeyboard bleKeyboard("M5StickC BLE Presenter");
// 电池更新
unsigned long nextVbatCheck = 0;
// 计时器
unsigned long startTimer = 0;
// 剩余电量
int getVlevel() {
  float vbat = M5.Axp.GetBatVoltage();
  int vlevel = ( vbat - 3.2 ) / 0.8 * 100;
  if ( vlevel < 0 ) {
    vlevel = 0;
  if ( 100 < vlevel ) {
    vlevel = 100;
  return vlevel;
  M5.begin();
  M5.Axp.ScreenBreath(9);
  setCpuFrequencyMhz(80);
  M5.Lcd.setTextSize(2);
  M5.Lcd.setCursor(0, 16);
  M5.Lcd.println("BLE Presenter");
  M5.Lcd.println(" BtnA :Next");
  M5.Lcd.println(" BtnB rev");
  M5.Lcd.println(" BtnP :Reset");
  // 只能在启动时设定电池余量
  bleKeyboard.setBatteryLevel(getVlevel());
  bleKeyboard.begin();
  // 按钮状态更新
  M5.update();
  // 按键操作
  if (bleKeyboard.isConnected()) {
    if ( M5.BtnA.wasPressed() ) {
      // 使用主页按钮推进幻灯片
      bleKeyboard.write(KEY_RIGHT_ARROW);
    if ( M5.BtnB.wasPressed() ) {
      // 用右键恢复幻灯片
      bleKeyboard.write(KEY_LEFT_ARROW);
    if ( M5.Axp.GetBtnPress() != 0 ) {
      // 用电源按钮进行计时器复位
      startTimer = millis();
  } else {
    // 没有连接的情况下不能进行计时器
  // 电池余量更新(每1分钟)
  if (nextVbatCheck < millis()) {
    M5.Lcd.setCursor(112, 0);
    M5.Lcd.printf("%3d%%", getVlevel());
    nextVbatCheck = millis() + 60000;
  // 计时器显示
  int min = ( millis() - startTimer ) / 1000 / 60;
  int sec = ( millis() - startTimer ) / 1000 % 60;
  M5.Lcd.setCursor(0, 0);
  M5.Lcd.printf("%5d:%02d", min, sec);
  // 等待
4.蓝牙串口工具
#include <BluetoothSerial.h>
BluetoothSerial SerialBT;
uint64_t chipid;
char chipname[256];
  chipid = ESP.getEfuseMac();
  sprintf( chipname, "SerialBT_%04X", (uint16_t)(chipid >> 32));
  M5.begin();
  M5.Lcd.printf("Bluetooth: %s\n", chipname);
  M5.Lcd.printf("Ver: %s %s\n", __DATE__, __TIME__);
  M5.Lcd.println();
  M5.Lcd.printf("Val:");
  SerialBT.begin(chipname);
  int val = analogRead(33);
  Serial.println(val);
  SerialBT.println(val);
  M5.Lcd.setCursor(8*4, 8*3);
  M5.Lcd.printf("%4d", val);
签到天数: 45 天
发表于 2021-2-3 11:23 | 显示全部楼层
这2个蓝牙的库有吗?
arduino程序设计基础 blinker物联网解决方案
【教程】pico+hx711电子秤
【教程】pico+hx711电子秤
ESP8266+Onenet平台远程数据传输和控制
ESP8266+Onenet平台远程数
【Arduino】108种传感器模
ps2遥控小车——uno实现
ps2遥控小车——uno实现
震惊!OLED菜单竟只用10行代码就可以完成到完美!!!
震惊!OLED菜单竟只用10行
震惊!OLED菜单竟只用10行代码就可
