查看: 79|回复: 1
[未解决] 共阳数码管,累加器大神帮我看看哪里有问题,
发表于 2020-6-30 23:22 来自手机 | 显示全部楼层 |阅读模式
define a_ 2
#define b_ 3
#define c_ 4
#define d_ 5
#define e_ 6
#define f_ 7
#define g_ 8
#define com1 10
#define com2 11
#define com3 12
#define com4 13
int anjian_=9;
int kai_=1;
int muu=0;
unsigned char TAB[10][7]=
  {0,0,0,0,0,0,1},
  {1,0,0,1,1,1,1},
  {0,0,1,0,0,1,0},
  {0,0,0,0,1,1,0},
  {1,0,0,1,1,0,0},
  {0,1,0,0,1,0,0},
  {0,1,0,0,0,0,0},
  {0,0,0,1,1,1,1},
  {0,0,0,0,0,0,0},
  {0,0,0,0,1,0,0},
pinMode(a_,OUTPUT);
pinMode(b_,OUTPUT);
pinMode(c_,OUTPUT);
pinMode(d_,OUTPUT);
pinMode(e_,OUTPUT);
pinMode(f_,OUTPUT);
pinMode(g_,OUTPUT);
pinMode(com1,OUTPUT);
pinMode(com2,OUTPUT);
pinMode(com3,OUTPUT);
pinMode(com4,OUTPUT);
pinMode(anjian_,INPUT_PULLUP);
  if(anjiansao()==1)
    muu++;
  if(muu>9999)
    muu=9999;
disply(1,muu/1000);
delay(3);
disply(2,muu%1000/100);
delay(3);
disply(3,muu%100/10);
delay(3);
disply(4,muu%10);
delay(3);
unsigned char  anjiansao()
  if(kai_ && digitalRead(anjian_)==LOW)
  { kai_=0;
    delay(20);
    if(digitalRead(anjian_)==LOW)
      return 1;
  if(digitalRead(anjian_)==HIGH)
      kai_=1;
      return 0;
void disply(unsigned char com,unsigned char muu)
  digitalWrite(a_,HIGH);
  digitalWrite(b_,HIGH);
  digitalWrite(c_,HIGH);
  digitalWrite(d_,HIGH);
  digitalWrite(e_,HIGH);
  digitalWrite(f_,HIGH);
  digitalWrite(g_,HIGH);
  switch(com)
    case 1:digitalWrite(com1,HIGH);
           digitalWrite(com2,LOW);
           digitalWrite(com3,LOW);
           digitalWrite(com4,LOW);
    case 2:digitalWrite(com1,LOW);
           digitalWrite(com2,HIGH);
    case 3:digitalWrite(com1,LOW);
           digitalWrite(com3,HIGH);
    case 4:digitalWrite(com1,LOW);
           digitalWrite(com4,HIGH);
    default:
  digitalWrite(a_,TAB[muu][0]);
  digitalWrite(b_,TAB[muu][1]);
  digitalWrite(c_,TAB[muu][2]);
  digitalWrite(d_,TAB[muu][3]);
  digitalWrite(e_,TAB[muu][4]);
  digitalWrite(f_,TAB[muu][5]);
  digitalWrite(g_,TAB[muu][6]);
 楼主| 发表于 2020-6-30 23:28 | 显示全部楼层
按键按出来不对
求助,用l298n模块控制电
绑定github账号,免费增加设备额度
绑定github账号,免费增加
